Carbonite Ultra Dashboard connections
  • 1.  Carbonite Ultra Dashboard connections
    Posted 10-18-2019 08:09
    How many Dashboards can be connected to a Carbonite Ultra frame?
  • 2.  RE: Carbonite Ultra Dashboard connections
    Posted 03-19-2021 15:38
    Hi Jimmy,
    Sorry for the late reply....  There is no official number that can be connected.  As more and more connections are established then the system needs to update them one by one when changes occur... So this time can increase as more and more are added.
    Using the DashBoard Proxy Server you can setup a DashBoard client running on a PC to be the "gateway" for all the other connections.  This would place the "load" on that PC and then only be a single connection between the Carbonite and DashBoard.  This is also the best way to connect "remote clients" that are accessed via VPN...  Once local machine connects them to the Carbonite.
    #Carbonite
