RCP-QE AS AUX PANEL
  • 1.  RCP-QE AS AUX PANEL
    Posted 05-01-2020 12:32
    I set up the rcp-qe panel as aux panel for carbonite switcher. Panel works, but, when choosing a source - the button does not change color, is it possible to make it change?
  • 2.  RE: RCP-QE AS AUX PANEL
    Posted 03-19-2021 15:50
    This looks like it has to do with the Level Mask and "default" level for the panel...
    ie if you have the switcher Level Set to 2 and then your panel is doing a level mask with 1 in it then the panel is going to display 1 first.
    Probably best to set the config in the Carbonite to be Level 1.
    #Carbonite
