Bus Map Settings Save
  • 1.  Bus Map Settings Save
    Posted 08-18-2020 14:54
    Hello All,
    Does anyone know if it's possible to save the Bus Map settings by either saving as a switcher Set, or a Memory? I need to be able to switch between different setting states and at present the Xpt settings are not saving for me.
    Carbonite - Software: 13.0.2.17165, Mode MiniME FCFS
  • 2.  RE: Bus Map Settings Save
    Posted 03-19-2021 15:25
    Bus Maps save with the personality of the switcher.  If you are having an issue I would try another USB drive..
    #Carbonite
