Output Labelling in Ultra Update
  • 1.  Output Labelling in Ultra Update
    Posted 05-13-2021 10:28
    Good day Les & Team,
    Thanks for Ross Videos hard work always trying to improve your products, it doesn't go unnoticed.  I have just a quick question (hopefully) in the update prior to 5.06, I watched your video and it said that the Naming of Outputs was part of the update.  We have a Carbonite Ultra July 2020 & CB2 panel, after I did the update, I couldn't change the output names like you did in the video.  Am I missing something?  Or was it just for Touchdrive?
    Thanks and I look forward to your response.
    Brad
    Brad W. Smith
    WESTMAN COMMUNICATIONS GROUP
    Mobile Producer/Technical Engineer
  • 2.  RE: Output Labelling in Ultra Update
    Posted 05-13-2021 11:02
    Hi Brad,
    Sorry I did answer in the other thread but it appears my posts are going into moderation.... Which I can approve my self??  Here is the same response..
    With version 5.1 of GRAPHITE we just introduced an ability to Name the outputs... with a Label field...
    In The Other Carbonite lines that has not yet been implemented.  However you can name the Buses .... in the Configuration Menu - Inputs - Internal menu you will find all of the "buses" have editable Names.  So Any Aux Can be renamed or ME Bus can be renamed that way...
    Les O'Reilly
    Product Manager - Production Switchers
  • 3.  RE: Output Labelling in Ultra Update
    Posted 05-13-2021 11:07
    Ok thanks Les, sorry I didn't see it in the other post for some reason.
    We have renamed them that way for the time being, we were just excited to see the Output naming option.  Fingers crossed we will see it in the future.
    Brad W. Smith
  • 4.  RE: Output Labelling in Ultra Update
    Posted 05-13-2021 11:56
    It was stuck in moderation so you would not have seen it :)
    We would like to make as many of the features from Graphite/Carbonite be the same but sometimes they can't always align on released times.
    Les
    Les O'Reilly
