RAVE mixer and GRAPHITE... saving RAVE presets ???
  • 1.  RAVE mixer and GRAPHITE... saving RAVE presets ???
    Posted 04-19-2021 15:04
    Hello All,
    I use GRAPHITE+RAVE.  i could spend a lot of time configuring the RAVE mixer.  What I dont understand is how to save all the adjustments like mix/minus settings, etc, etc. to a RAVE setup file.  Is there such a thing such as a RAVE setup file?
    We have many people touching our GRAPHITE and once in a while - stuff happens - and we need to quickly reset RAVE settings.
    Should I be looking in the DASHBOARD UI for saving our RAVE save-settings or might it be in the GRAPHITE UI?
    Thanks guys
    nervous nellie
    Robert Vanrhyn
    CNBC
  • 2.  RE: RAVE mixer and GRAPHITE... saving RAVE presets ???
    Posted 04-19-2021 15:19
    Hi Robert,
    You can store this with a memory.  Just like an Auxbus or a Media Store you can include Mixers when you store and recall a memory.  You can also make Custom Control Macros that can setup values as well... This is how I have my "audio Reset" configured for setting up levels and Pre-Post plus Mutes and other levels inside of My Custom Control...
    Les O'Reilly
    Product Manager - Production Switchers
  • 3.  RE: RAVE mixer and GRAPHITE... saving RAVE presets ???
    Posted 04-20-2021 09:01
    Les,
    As always, thank you for the quick response.
    i am using Dashboard 9.2 with latest GRAPHITE.  I am able to create a memory for every region of the graphite system except RAVE!
    When I save switcher memories I see the saved GRAPHITE resource-label right on the memory.  If I save ME1 and ME2 memory, the memory button on dashboard reads ME1 ME1.
    I can never get a memory button to save/display an audio resource - and yes,  I definitely enabled the audio regions in the memory menu.
    I think I will have engineering dept call tech support and have someone log on to confirm my dilemma...
    Thanks les
    Robert Vanrhyn
    CNBC
  • 4.  RE: RAVE mixer and GRAPHITE... saving RAVE presets ???
    Posted 04-20-2021 12:28
    under the Recall Attributes you would want to make sure that the Audio Mixer is set to (orange) so that the Memory Store Attribute is allowed to run...
    These are probably set to "No Recall (Grey)" and thus even though you are adding it to your Memory Attributes on the Store side it will be over ridden to prevent it...
    Then Before you "Store" the memory...... Now you have to store it with a ME MiniME or Canvas....  There is no separate "Audio Only" Inclusion...  Yes this is a Feature request on the "List" of things that we would like to get  done and Move Audio from being a inclusion like Aux Buses and have then instead be More like a separate ME memory On their own.
    Les O'Reilly
  • 5.  RE: RAVE mixer and GRAPHITE... saving RAVE presets ???
    Posted 04-20-2021 13:13
    I did all that Les, no save or recall of audio settings via memories.  Macro control of RAVE is fine but memory recall is way preferable.  We will call for help.
    Thank you sir.
    Robert Vanrhyn
    CNBC
