  • 1.  Individual character spacing
    Posted 11-05-2021 09:59
    This is a basic question, but is there a way to change spacing between specific characters without switching to a new font with a different kerning?  Depending on the font, certain characters may space unevenly.  Using control alt arrow you can easily change leading. Is there a character kerning equivalent?
  • 2.  RE: Individual character spacing
    Posted 11-05-2021 15:25
    Ctrl and Numpad Plus/Minus will adjust the kerning between two invidiual characters while editing a text object in layout mode.
    But beware, this kerning will be lost if this text object is published to the sequencer; because the text entered into the template data of the sequencer will replace everything in the text object from the layout.  You would want to unpublish the text object from the scene for custom kerning to be retained.
    Brian Ford
