  • 1.  Deploying via Project Server
    Posted 11-24-2021 12:59
    I am attempting to add a small subset of graphics to our existing project via the project server. This is just a dozen scenes for a seasonal show we're running while continuing production on our other shows, so I'd like to reserve both our current graphics, but make this set available to use, as well. We are a newsroom utilizing the MOS Gateway editor within iNews.
    I have been able to create a new category of graphics within our project server, but when I deploy or publish this project to the server, I do not see any scenes available to edit within iNews.
    Does anyone have any thoughts on what I'm doing wrong?
    Dan Jensen
    WREX (Quincy)
  • 2.  RE: Deploying via Project Server
    Posted 11-24-2021 14:50
    The category feature on Project Server is for a workflow feature called Project Server Styles, what you describe here should not be using that feature. I would delete the category you have created on the Project Server (carefully).
     It sounds like you have created a new Project file with these new scenes. In that case, you should create a new SHOW on the Project Server. Once you have published to that Show on the Project Server you can open it in the MOS plugin by clicking the "Browse" button (3 dots):
    From there you'll be able to open different projects on your project server in the MOS plugin. You can have multiple shows/projects in your MOS rundown. The Preview Engine and Studio/BlueBox Output Engines can load multiple projects simultaneously.
  • 3.  RE: Deploying via Project Server
    Posted 11-24-2021 15:36
    Thank you, Garner. This was the solution and is working correctly.
    Dan Jensen
    WREX (Quincy)
