  • 1.  XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-09-2021 15:28
    I've just installed XPression Studio V10.5 64bit on our Corvid 88 system.
    I've installed the AJA 12.5.7 drivers.  (re: the XPression Video IO Cards & 3rd Party Driver Specs)
    Should I be using this latest Corvid 88 firmware with the 12.5.7 drivers?
    'Version 0x3f - 4/28/2021 - corvid_88_2021-04-28.bit'
    D'Arc
    DArcy Pickering
    BANNISTER LAKE SOFTWARE
  • 2.  RE: XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-24-2021 10:44
    Hi Darcy,
    The AJA Control Panel will report what firmware is already installed on the board and which firmware is desired for this driver version. If the two don't match, update the firmware. This firmware is included with the driver so always is the right version.
    Kind regards,
    Gerard de Vries
    Solution Architect Live Graphics & Virtual Graphics
    EMG
    The Netherlands
  • 3.  RE: XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-24-2021 11:12
    Hi Darcy,
    I read you DM, but I prefer to answer in the 'open' channel so other also benefit. I initially missed that you are using a 64-bit version of XPression.
    Not sure if this helps, but we're using V15.5.3 of the AJA-driver with the firmware it comes with. However we're still using the 32-bit version.
    Kind regards,
    Gerard de Vries
    EMG
    The Netherlands
  • 4.  RE: XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-24-2021 11:57
    Hi Gerard
    I can use any version of the AJA NTV2 driver/firmware with XPression 32bit.
    The question I posed to Flint is what combination of driver/firmware supports 64bit.
    D'Arc
  • 5.  RE: XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-24-2021 14:53
    Hi D'Arcy,
    We're currently investigating this issue in our lab. XPression 32bit/64bit are supposed to support the same AJA driver/firmware.
  • 6.  RE: XPression Studio V10.5 64bit with AJA Corvid 88
    Posted 11-24-2021 15:04
    Thanks for the update Garner.
    D'Arc
    D'Arcy Pickering
    VP Sales
    Bannister Lake
    dpickering@bannisterlake.com
    Cell: +1 519.572.3900
    https://www.bannisterlake.com
    Sent from my Key2
