  • 1.  What Hardware do I need to run xpression
    Posted 6 days ago
    Hi Red,
    I'm running designer to build the gfx for Saturday Night Takeaway and have booked into the training on 31st Jan. I want to make sure my pc is up to speed and upgrade it if necessary. I've had a play around with converting mov files in Xpression coder which is pretty straightforward but they're not playing so I'm guessing the spec of my pc doesn't suit. Can you tell me what spec I need please?
    Many thanks,
    Tracie
  • 2.  RE: What Hardware do I need to run xpression
    Posted 6 days ago
    Hi Tracie,
    The main thing you need is an Nvidia GPU, newer the better but I'd recommend at least a 1000 series. At least 8GB ran but I'd recommend 16GB or above. CPU newer the better but I'd recommend i7 or above.
    Here is the specs of our XPression Go system from 2019, that's a good rough guide for what you should aim for as a baseline.
    https://documentation.rossvideo.com/files/Cut%20Sheets/XPression/XPression%20GO%20&%20GO%20Mini%20Supported%20Hardware%20Specs(3701DR-004).pdf
    Cheers,
    Red
