  • 1.  Xpression: Shifting "Last Name" Cell Based on "First Name" Cell
    Posted 11-05-2021 18:09
    I cannot remember what it is called, to have a second text cell, in horizontal alignment BEHIND a first cell, SHIFT TO THE RIGHT OR LEFT with a degree of spacing, dependent on the length of the first cell.
    IE I have to have my first and last name, in order, in two different cells, and I need the last name to shift over with a preset amount of padding, based on the length of the first name. I need to know HOW to set this up in Xpression.
    SaraBeth Groover
  • 2.  RE: Xpression: Shifting "Last Name" Cell Based on "First Name" Cell
    Posted 11-05-2021 18:49
    in visual logic you can use the text bounding box of the first name to set the position of the last name when you add an offset.
    TV Syndicate/Icon Fitness
  • 3.  RE: Xpression: Shifting "Last Name" Cell Based on "First Name" Cell
    Posted 11-05-2021 19:38
    you can also concatenate the first and last names so they become a single text field using scripting
  • 4.  RE: Xpression: Shifting "Last Name" Cell Based on "First Name" Cell
    Posted 11-06-2021 07:29
    There is also a concatenate block in visual logic now.
