Just installing a new Carbonite Ultra frame, and we're seeing a similar issue with DashBoard Version 9.2.1 and Big Sur 11.6.
The workaround got us up and running, but I wanted to pass the info along.
Christopher Palazini
Technical Director / Video Engineer
Hartford Healthcare Amphitheater
Sent: 11-18-2020 16:34
Subject: Workaround for DB not launching on OSX Big Sur.
The DashBoard team has identified an issue with the latest Mac OS, Big Sur, where any version of DashBoard will not launch. We have a workaround, but our advice right now is to hold off on upgrading to Big Sur if you can. It seems that other vendors are having similar issues with the new OS as well. The DashBoard team will be looking into a fix, but currently we do not have a timeline for the release.
Current Workaround
DashBoard can still be launched on Big Sur by navigating into the Contents of the DashBoard.app. A default install location for DashBoard can be launched from the terminal with the following command:
open /Applications/DashBoard/DashBoard.app/Contents/MacOS/PermissionDashBoard
You can also dive into the contents from inside Finder by right mouse clicking on the DashBoard.app and selecting "Show Package Contents". From here, navigate into the Contents folder, then into the MacOS folder, and finally run PermissionDashBoard.
