Hi Ding,
You can use dragvalue attributes that can return basically the dragids here.
Please find the attached code for the panel.
<abs gridsize="20" keepalive="true">
<label height="60" left="40" name="Drag and Drop Examples" style="txt-align:west;size:Bigger;" top="40" width="620"/>
<label height="20" left="40" name="Drag and drop is handled by using ogscript blocks that handle "dragvalue" and "ondrop" events, with specific targets." style="txt-align:west;" top="100" width="1100"/>
<label height="20" left="40" name="Look at the two "ogscript" blocks in this panel for examples." style="txt-align:west;" top="120" width="1120"/>
<label dragvalue="return 'drag1';" height="100" id="dragspot1" left="120" name="DRAG ME 1" style="txt-align:center;bdr:round;bg#selectbg;" top="260" width="100"/>
<label height="320" id="dropspot" left="320" name="Drop it here!" style="size:Big;bg#dark;txt-align:center;bdr:etched;" top="240" width="200"/>
<ogscript handles="ondrop" targetid="dropspot">ogscript.rename('dropspot', 'Dropped: "' + event.dropData + '"');</ogscript>
<label dragvalue="return 'drag2';" height="100" id="dragspot2" left="120" name="DRAG ME 2" style="txt-align:center;bdr:round;bg#selectbg;" top="400" width="100"/>
Anand
Anand Soraganvi
Sent: 08-15-2021 22:35
Subject: Drag and Drop in dashboard
Hi:
I want the drag label to be in the format shown in the figure below. I want two different DRAG objects to assign different values to the drop object, and instead of writing two ogScript tags, I want to be able to identify the specific DRAG object ID and return different values between "drag" and "drop". Is there an event that does this?
PS: The event attribute in dashboard is not found in the help document where I should look for it.
<abs gridsize="20" keepalive="true"> <label height="60" left="40" name="Drag and Drop Examples" style="txt-align:west;size:Bigger;" top="40" width="620"/> <label height="20" left="40" name="Drag and drop is handled by using ogscript blocks that handle "dragvalue" and "ondrop" events, with specific targets." style="txt-align:west;" top="100" width="1100"/> <label height="20" left="40" name="Look at the two "ogscript" blocks in this panel for examples." style="txt-align:west;" top="120" width="1120"/> <label height="100" id="dragspot1" left="120" name="DRAG ME 1" style="txt-align:center;bdr:round;bg#selectbg;" top="260" width="100"/> <label height="320" id="dropspot" left="320" name="Drop it here!" right="2580" style="size:Big;bg#dark;txt-align:center;bdr:etched;" top="240"/> <ogscript handles="dragvalue" targetid="dragspot1,dragspot2">return 'drag1';</ogscript> <ogscript handles="ondrop" targetid="dropspot">ogscript.rename('dropspot', 'Dropped: "' + event.dropData + '"');</ogscript> <label height="100" id="dragspot2" left="120" name="DRAG ME 2" style="txt-align:center;bdr:round;bg#selectbg;" top="400" width="100"/></abs>
Ding YouXing
