  • 1.  Sending RossTalk commands to Caprica from Carbonite Ultra
    Posted 03-30-2023 08:36
    Hello Les & Co.
    I'm trying to send some commands from Carbonite to Caprica. In the device section I've added a generic device with Caprica IP. I used the port 7788 and set Roll Clip to Off. Then, in Custom Control I tried to run a simple CC targeting that Device, that should have run another CC in Caprica
    I used first the menu "Devices/RossTalk (Generic)/CC" - it didn't work
    Then I tried "Devices/RossTalk (Generic)/RossTalk Custom Command" and wrote in the text box "CC bank:cc" - it still didn't work
    Do you have any clue about what I'm doing wrong? Do I use the wrong port?
    Thank you,
    Sorin
    Sorin Podeanu
    technical director
    Euronews Romania
  • 2.  RE: Sending RossTalk commands to Caprica from Carbonite Ultra
    Posted 03-30-2023 11:50
    You do have to setup a RossTalk IN Device on Caprica.
    Make sure you have that enabled.  It's probably what is missing.
    Les O'Reilly
    Director - Switcher Product Management
  • 3.  RE: Sending RossTalk commands to Caprica from Carbonite Ultra
    Posted 03-30-2023 12:15
    Hi Les!
    Yes, that was it! I defined a RossTalk device on Caprica with the Carbonite IP, put it as server instead of client and it worked! Both methods worked, the built in CC menu from Carbonite and the manual command containing the bank:cc line
    Thanks for your help!
    Sorin Podeanu
    technical director
    Euronews Romania
