Setting a pause at the beginning of a scene that is already online
  • 1.  Setting a pause at the beginning of a scene that is already online
    I have a layer that is a video that I need to be online, but at a pause first. Then I need it to trigger that, maybe a keystroke/spacebar, to then animate and the other elements animate on also.
    Help!!!??
    Michele Hampton
    MICHELE HAMPTON
  • 2.  RE: Setting a pause at the beginning of a scene that is already online
    Add a pause to the first or second frame of the scene director.  Instead of setting the video to be "autostart and freerunning", just drag the video material onto a track on the scene director, and that will cause the video to respect the "pause" on the scene director.
    When you play the scene through the sequencer it should immediately go into the "paused" state with the video frozen.  Taking the item again will start everything playing.
    Brian Ford
