Hi Garner and Les,
Thank you for all your input. When I want to change Carbonite connect to second NIC, I realized that Carbonite's current network cable is connected to its second NIC. Will it be a reason causing this issue? Furthermore I've tried to Ping Carbonite from Xpression, the latency is shorter then 1ms. It even shows "0 delay" between two platforms on command prompt.
Then I start to think the delay might be caused by Xpression processing time. All graphic I want to bring on air is "TGA Sequence" video, and it seems taking longer time to load. So, I use "Xpression Video Coder" to transcode these sequences into Xpression AVI and see latency time become shorter. Just like Les's explanation, Xpression takes a few time to load scenes and time being taken is related to complexity of scenes.
If the delay is really no way to avoid, how would you recommend me handle 3 keyers and Xpression at the same time perfectly? Use Media transition to cover this drawback? What would you do for it?
Thanks a lot for your help,
Ellis
