#XPression and DashBoard
  • 1.  #XPression and DashBoard
    Posted 05-28-2021 09:37
    Hello!
    I'm working with XPression and DashBoard and I've been wanting to create a Key Pad on DashBoard, so when I put the Take ID number and press the button "TAKE" it starts playing the clip I selected. I already have the "TAKE" button, I just need to get the Key Pad on DashBoard and connect it with XPression.
    Thank you!
    #XPression #DashBoard​​​
    Bruna Gregorio
  • 2.  RE: #XPression and DashBoard
    Posted 05-31-2021 17:32
    Hello Bruna,
    I've added the source code for a custom panel which has a number pad. The numbers entered on the number pad adjust the value of a parameter named "take_id". Once the desired number is input, you can click the "Take" button to print the value to the openGear Debug Information. You can show this debug window by selecting Views > openGear Debug Information within DashBoard.
    Printing the information is nice but you are trying to interact with XPression. You will need to edit the task assigned to the "Take" button. In the else statement, you should see a commented out RossTalk command. You will want to uncomment this line and replace the IP address with your XPression server. Then you should update the values on the TAKE argument. It should have the format of: TAKE [take ID]:[buffer ID]:[layer ID] . You will want to use the take_id parameter we created as the value for [take ID].
    Please let me know if you have any questions.
    <abs contexttype="opengear" gridsize="20" id="_top" keepalive="false" virtualheight="921" virtualwidth="1498">
       <meta>
          <params>
             <param access="1" maxlength="0" name="take_id" oid="take_id" type="STRING" value="" widget="text"/>
          </params>
          <api>function addNumber(num) {
       var value = params.getValueAsString('take_id', 0);
       new_value = value + num;
       params.setValue('take_id', 0, new_value);
    function clearNumber() {
       params.setValue('take_id', 0, "");
    }</api>
       </meta>
       <param expand="true" height="40" left="220" oid="take_id" showlabel="false" top="60" width="280"/>
       <label height="40" left="60" name="Take ID:" style="txt-align:west" top="60" width="160"/>
       <abs height="260" left="60" top="140" width="340">
          <simplegrid cols="4" height="180" left="0" rows="3" top="0" width="260">
             <button buttontype="push" name="1">
                <task tasktype="ogscript">addNumber(1);</task>
             </button>
             <button buttontype="push" name="2">
                <task tasktype="ogscript">addNumber(2);</task>
             </button>
             <button buttontype="push" name="3">
                <task tasktype="ogscript">addNumber(3);</task>
             </button>
             <button buttontype="push" name="Take">
                <task tasktype="ogscript">var value = params.getValueAsString('take_id', 0);
    if (value == "" || value == null){
    ogscript.debug("No number is entered");
    else{
    ogscript.debug("TAKE " +value);
    // rosstalk.sendMessage('172.16.x.x', 7788, 'TAKE 0:0:0');
    clearNumber();
    }</task>
             </button>
             <button buttontype="push" name="4">
                <task tasktype="ogscript">addNumber(4);</task>
             </button>
             <button buttontype="push" name="5">
                <task tasktype="ogscript">addNumber(5);</task>
             </button>
             <button buttontype="push" name="6">
                <task tasktype="ogscript">addNumber(6);</task>
             </button>
             <button buttontype="push" name="Clear">
                <task tasktype="ogscript">clearNumber();</task>
             </button>
             <button buttontype="push" name="7">
                <task tasktype="ogscript">addNumber(7);</task>
             </button>
             <button buttontype="push" name="8">
                <task tasktype="ogscript">addNumber(8);</task>
             </button>
             <button buttontype="push" name="9">
                <task tasktype="ogscript">addNumber(9);</task>
             </button>
             <button buttontype="push" name="0">
                <task tasktype="ogscript">addNumber(0);</task>
             </button>
          </simplegrid>
    Thanks,
    Dave Sampson
  • 3.  RE: #XPression and DashBoard
    Posted 06-02-2021 10:59
    Hello Dave,
    I hope you're fine.
    My name is João and I'm coworker of Bruna. We're developing this project ( key pad) together, and we already tested your programming, it's very useful for us, thanks a lot. However, the TAKE button didn't behaves as we expected, after pressed it the clip in my Xpression playlist doesn't start.  We verified the Opengear debug information, apparently everything is working as you said,  when I just hit take button the message ''no number is entered'' appears to me and when I type some number + take button the message '' take 9'' shows up.
    We also uncommented the line ''rosstalk.sendmessage'' and filled this field with our Xpression IP address. We can't understand why this command doesn't work.  Follow, below, our coding:
    <abs contexttype="opengear" dblinqport="2222" gridsize="20" id="_top" keepalive="false" virtualheight="921" virtualwidth="1498">
    <meta>
    <params>
    </params>
    }</api>
    <context contexttype="opengear" id="XPression.1" objectid="192.168.41.30:8020:XPression" objecttype="XPression"/>
    </meta>
    </button>
    </button>
    </button>
    else{
    rosstalk.sendMessage('192.168.41.30', 7788, 'TAKE take_id:0:0');
    clearNumber();
    }</task>
    </button>
    </button>
    </button>
    </button>
    </button>
    </button>
    </button>
    </button>
    </button>
    </simplegrid>
    If you could highlight any error in our coding, please, let me know.
    Thanks,
    João victhor Mariano
  • 4.  RE: #XPression and DashBoard
    Posted 06-02-2021 11:26
    Hi João,
    In the task for the Take button, we store the value of take_id in a variable called "value". We can use this in our RossTalk command.
    Also, keep in mind that we are building a string in the RossTalk command and variables cannot be referenced inside of quotes. In the code line below, notice how value is not contained within the quotes and we are using the addition sign to concatenate the strings.
    rosstalk.sendMessage('192.168.41.30', 7788, 'TAKE '+value+':0:0');
    Please let me know if this works for you.
    Dave Sampson
  • 5.  RE: #XPression and DashBoard
    Posted 06-02-2021 11:46
    Hello Dave,
    Now, it's clearer for us. After applied the changes suggested by you, the key pad panel is running well.
    Thank you very much for your time.
    My best,
  • 6.  RE: #XPression and DashBoard
    Posted 06-07-2021 10:30
    Hello Dave!
    First of all I would like to say thank you for your time and help! Our panel is working great!
    I have question about Dashboard and I'm not sure if it is a limitation or we could actually do that.
    So I've been wanting to visualize on DashBoard the blue line that appears on the XPression Sequencer, so I could see what clips are playing or the ones that were last played, I was able to drag & drop the Sequencer but I can't see the blue line. The Up and Down command is working, but the visualizing status is not. Is there a way we could do that?
    Thank you!
    Bruna Gregorio
  • 7.  RE: #XPression and DashBoard
    Posted 06-08-2021 11:47
    Hi Bruna,
    It's always great to hear when people are enjoying their custom panels.
    Unfortunately this feature will not be possible on your panel. DashBoard does not receive the necessary information to construct this line.
    Please let me know if you have any other questions as you develop your panel.
    Dave Sampson
  • 8.  RE: #XPression and DashBoard
    Posted 06-08-2021 12:49
    Hello Dave,
    Thanks you for your time. We've learned a lot during last weeks, and your support have been essential for this. It's really a pity, the Dashboard doesn't have the feature to able us see the blue indication line over clips.
    As we mentioned before, the key pad panel works fine and will fit our needs perfectly. However, we'd like to know if is it possible attributes the TAKE button action to ENTER button of my keyboard? we believe that it'll improve our operation.
    Thanks,
  • 9.  RE: #XPression and DashBoard
    Posted 06-10-2021 13:42
    Hi João,
    Below you will find the source of an updated version of the keypad panel I made previously. This should handle pressing the enter key to submit the take by either clicking the number buttons with the mouse, or by entering it into the text field. The enter functionality is possible because of the ogscript tags near the top. There are 3 things worth mentioning with these tags.
    The handles="onkeyrelease" will make DashBoard pay attention to keyboard input. There are a list of different values for the handles attribute in the DashBoard help but I chose "onkeyrelease" which will trigger after releasing a pressed down key.
    You may eventually want the enter key to do different things on your panel. So for now, we only want the enter key to submit a take if you are interacting with the text field or with the number buttons. This is where the targetid attribute comes in. This tells DashBoard to only trigger the onkeyrelease if this ID is in focus. Unless you specify otherwise, the last component you interact with will have focus. I added ogscript.focus("keypad"); in the addNumber() function to give focus to the parent <abs> container after clicking a number button.
    The third value worth mentioning in the ogscript tag is the checkEnter(event); text. This is the code that will run if a key is released and the right component is in focus. This submits the onkeyrelease event that occurred on either the number_entry or the keypad to the checkEnter() function. The checkEnter() function then retrieves the keycode that was pressed and determines if it was the enter key. If the keycode resolves to be the enter key, then the sendTake() function is triggered which carries out the functionality you have already seen.
    Please let me know if you have any questions when including this functionality in your panel.
       <meta>
          <ogscript handles="onkeyrelease" targetid="number_entry">checkEnter(event);</ogscript>
          <ogscript handles="onkeyrelease" targetid="keypad">checkEnter(event);</ogscript>
          <params>
          </params>
    function checkEnter(event){
    var keyCode = event.getKeyCode();
          var keyText = event.getKeyText(keyCode).toLowerCase();
          if (keyText == "enter"){
          sendTake();
    function sendTake(){
    else{
    // rosstalk.sendMessage('192.168.41.30', 7788, 'TAKE '+value+':0:0');
    clearNumber();
    }</api>
       </meta>
       <param expand="true" height="40" id="number_entry" left="220" oid="take_id" showlabel="false" top="60" width="280"/>
       <abs height="300" id="keypad" left="60" top="140" width="720">
             </button>
             </button>
             </button>
                <task tasktype="ogscript">sendTake();</task>
             </button>
             </button>
             </button>
             </button>
             </button>
             </button>
             </button>
             </button>
             </button>
          </simplegrid>
    Dave Sampson
  • 10.  RE: #XPression and DashBoard
    Posted 06-11-2021 10:50
    Hello Dave,
    I am glad to inform you that this update version of keypad panel worked fine. To be able to reproduce the TAKE action by pressing enter button was exactly what we needed. Also, your detailed explanation about this ogscript, opened our mind and helped us increment new features to our custom panel. Thank you very much for your attention!
    The next step, we would like to reach, is create a visualization box which allows us to see the clip that I play by my keypad or shot box panel. We tried do that creating a widget ``Xpression desktop preview`` and adding to it the parameters <param oid="Ext.CGTemp.DisplayTake" value="1"/>;
    <param oid="Ext.CGTemp.BackgroundStyle" value="bg#ff0000;"/>; <param oid="Ext.CGTemp.Layout.ImagePosition" value="east"/>, however, we didn´t get success. Do you know what we´re doing wrong?
    Thanks,
  • 11.  RE: #XPression and DashBoard
    Posted 06-11-2021 15:37
    Hi João,
    Following up on the sequencer preview question. When you're using this Dashboard, do you have the XPression sequencer also up on a different monitor/window? If you want to focus the blue line on the item you just took to air, rather than sending a "TAKE" RossTalk command, you can always do a Sequence In, or "SEQI" RossTalk command. This will take your graphic to air and also shift the sequencer to the item you just took to air.
    Drew Shealy
    XPression Designer & Programmer
    SoFi Stadium
  • 12.  RE: #XPression and DashBoard
    Posted 06-14-2021 10:23
    Hello Drew,
    Thanks for your attention in our case. I don´t know if I was clear in my previous question related to Xpression sequencer, but we created a simple panel containing two arrows (up and down) and a TAKE  button, which basically use the arrows to select the clip in my playlist and Take button to play it. However, when I hitting the arrows I can´t see the blue bar moving over the clips as I see in the Xpression, so I need to deduce which clip I´ll run counting how many times I triggered my arrows. It just highlighted the clip after I pressed TAKE button. It isn´t user friendly.
    Dave informed us that it isn´t possible to see in Dashboard, because Dashboard does not receive the necessary information to construct this line. So, if you know a way to overcome it, it´ll be very useful for us.
    Thanks,
  • 13.  RE: #XPression and DashBoard
    Posted 06-16-2021 11:17
    Hi João,
    To setup the XPression Desktop Preview widget, place the widget into your custom panel and
    specify which channel of XPression you would like to show.
    From XPression, click the Edit > Hardware Setup option. Select the "Inputs/Outputs" tab and click "Add". Next, choose "XPression Desktop Preview Client" as the brand. Enter the IP address of your DashBoard computer and select the channel you would like to send.
    Dave Sampson
  • 14.  RE: #XPression and DashBoard
    Posted 06-18-2021 09:49
    Hello Dave!
    I'm still working with João in that case and I tried to do what was told but it doesn't seem to work. I'll send you the images of the steps and if you could point me anything that you might think it's wrong it would be very helpful.
    I created the widget on DashBoard and chose the Channel 1, then I added the DashBoard Computer on Xpression and it shows "Active" but nothing shows up on Dashboard.
    Thank you for your time.
    Bruna Gregorio
  • 15.  RE: #XPression and DashBoard
    Posted 06-21-2021 17:08
    Hi Bruna,
    I was experiencing the same issue as you when I configured this locally. XPression would show the Desktop preview client as active and DashBoard would only show a black bar with the channel number on the custom panel.
    I managed to fix the issue by restarting XPression after configuring the Desktop preview client. Any changes I made to the channel number while XPression was open did not take effect until XPression restarted.
    DashBoard only requires you to provide the correct channel number. All other configuration is done on XPression. If you are still having issues with this widget I suggest leaving a post on the discussion board for XPression. Here is the link to their discussion board:
    Discussion board for XPression
    Please let me know if restarting XPression helps.
    Dave Sampson
  • 16.  RE: #XPression and DashBoard
    Posted 06-22-2021 10:57
    Hello Dave!
    I tried to restart the Xpression but unfortunately it didn't work, it keeps showing me only the black bar on Dashoard.
    But I will ask about that on the discussion board you sent me, hopefully it will help me solve the problem.
    Thank you so much for your time and patience, you've helped us a lot!
    Our panel looks very nice thanks you, the way you teached and showed us the codes was amazing.
    Thank you so much and have a great day!
    Bruna Gregorio
  • 17.  RE: #XPression and DashBoard
    Posted 11 days ago
    Hello Dave,
    I'm back because I'm having an issue with the KeyPad and I believe you could help me.
    So everything was working ok but when I have a project where I use 2 framebuffers, when I put a take ID and it's supposed to play on Framebuffer 2 it automatically goes to Framebuffer 1 when I press "TAKE" on the KeyPad. I'm not sure why this happens, do you have any thoughts about that?
    Thank you so much!
    Bruna Gregorio
  • 18.  RE: #XPression and DashBoard
    Posted 11 days ago
    Hi Bruna,
    Great to hear from you again.
    You may recall that we had a RossTalk command being triggered when we clicked the TAKE button. In the source code, it looked something like this:
    rosstalk.sendMessage('192.168.1.30', 7788, 'TAKE '+value+':0:0');​
    This sends a string message to IP address 192.168.1.30 on port 7788. The string actually has the format of:
    TAKE [take ID]:[buffer ID]:[layer ID]​
    You can see we are providing the take ID with the "value" variable but have left the [buffer ID] and [layer ID] at defaults of 0. If you want to use a different buffer ID, we just need to replace the 0 with the correct value. I believe 0 represents frame buffer 1 and a value of 1 would represent frame buffer 2.
    I'm not sure how you would like this designed within your panel. One approach would be to keep the keypad reserved for the take IDs and make a separate integer parameter displayed as a spinner to control the frame buffer ID. You could then retrieve this value whenever the TAKE button is clicked, and replace the 0 inside the RossTalk command.
    Dave Sampson
  • 19.  RE: #XPression and DashBoard
    Posted 7 days ago
    Hello Dave,
    Thank you for your time! So I replaced the 0 in the code with a different value and it worked, but I was trying to use the 2 buffers ID. We have an example project (Ross News Hour) where we use two different framebuffers and I would like to use them both.
    On the Sequencer the buffer ID is already pre-selected so what I'm trying to do is press "TAKE" without changing the buffer ID.
    I think we are able to do that on the code but I'm not quite sure how.
    Thank you!
    Bruna Gregorio
  • 20.  RE: #XPression and DashBoard
    Posted 6 hours ago
    Hi Dave, sorry to bother you again,
    Do you have any updates on my case?
    I'm more invested on this panel because we will be showing to clients so we want everything to be working great.
    Thank you!
    Bruna Gregorio
