No audio coming in off HDMI
  • 1.  No audio coming in off HDMI
    Posted 13 days ago
    Hi all...  I have no audio coming in off HDMI...  Put it into HDMI in...  Switch to it and no sound...  any tips? Oh I have a Carbonite Solo
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 2.  RE: No audio coming in off HDMI
    Posted 13 days ago
    There is no Audio on the HDMI inputs even when on the Background since they have to have a Frame Sync Applied and that will strip the audio off the source.
    Les O'Reilly
    Director - Switcher Product Management
  • 3.  RE: No audio coming in off HDMI
    Posted 13 days ago
    Weird it worked before....  so HDMI ins can't take audio then?
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 4.  RE: No audio coming in off HDMI
    Any source that is Frame Synced will not pass Audio..
    The Solo does not have an "audio mixer" in it...  Ancillary Data is passed based on the source that is on the Background.  However you will not get audio from a source selected on the Background that is going through a Frame Sync.
    Les O'Reilly
  • 5.  RE: No audio coming in off HDMI
    Any suggestions how I can keep the audio info in the signal?  I can use any other sources - for example SDI?
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 6.  RE: No audio coming in off HDMI
    If any source has a Frame Sync it will strip the Audio...
    Les O'Reilly
  • 7.  RE: No audio coming in off HDMI
    Could I store a video in the switcher itself or xpression?  How can I cue a video with audio?  How would a power point work with audio clips?  How do broadcasters cue their videos w/ audio?
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 8.  RE: No audio coming in off HDMI
    Been reading some forums...  Would I need to get something like aja fs1?
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 9.  RE: No audio coming in off HDMI
    You need an Audio Mixer...
    The Solo switcher does not have a built in Audio Mixer..
    You need to send all of the audio to an audio mixer and then use an Embedder to put that Audio back onto the PGM output.
    Les O'Reilly
  • 10.  RE: No audio coming in off HDMI
    What Ross gear would you suggest I purchase to make this happen?
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 11.  RE: No audio coming in off HDMI
    You would have to look at the Carbonite Ultra series since that does have an Audio Mixer Built in...
    Then just use low cost HDMI to SDI converters ... then Frame sync in Ultra which has Sample Rate converters to handle the audio..
    Les O'Reilly
  • 12.  RE: No audio coming in off HDMI
    If I get the Ultra series...  Can't I just use HDMI ins or do they have to be SDI ins?  Thanks so much for all your help and info so far - just wanted to say that.  It has been very helpful and informative.
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 13.  RE: No audio coming in off HDMI
    Ultra does not have HDMI inputs..
    I use 5 of these with mine :)...  Have an extra one or two incase one is to fail.
    https://www.amazon.com/Converter-Adapter-HD-SDI-Support-Theater/dp/B01FSQBVJE/ref=sr_1_10?dchild=1&keywords=HDMI+to+SDI+converter&qid=1631644129&sr=8-10
    Les
    Les O'Reilly
