Hello Les and Nate! Thanks for the answer. I will try playing with those CCs.
Also, Nate, I know this is a switcher thread, not a Caprica one, but I have another question, if you are kind to answer. In Input setup in Caprica, there is a field "OnAir CC". I've added a simple CC to be triggered whenever the source is on air, but it doesn't work. I tried both cutting directly on switcher and running them through Overdrive. How is this supposed to function?
Thank you
sorin podeanu
technical director
Euronews Romania
Sent: 03-19-2023 14:02
Subject: Is there a way to make the audio mixer ignore a key press on the Carbonite switcher?
Hi Sorin. Try making a Caprica Custom Control to Disable AFV (Audio Mixer>Disable AFV) and then select the source. You could make CCs that Disable AFV and cut to each source. Once you advance your OverDrive playlist, the settings would switch back to however the shot was coded.
Nate Wright
Sent: 03-18-2023 06:43
Hello!
I have enabled Caprica to control a mic and 4 video servers on a Calrec audio mixer. If I switch only between them, the faders go up and down as intended. So far so good. But if I press any other source on the video switcher, the audio mixer will cut off the faders, obviously.
I can make it work if I run everything through Overdrive, but sometimes we need to cut directly on the switcher. So is there a way to make the audio mixer to ignore certain keys presses to keep the previous audio source up? I tried to pass the sources through AUX buses, but the mixer still cuts off the audio
We have a Carbonite Ultra switcher, version 6.6.7.8260
Thank you
Sorin
