Connectivity
Virtual Output not playing the scene
  • 1.  Virtual Output not playing the scene
    Hello, I hope someone can help and I'm in the right community or someone can point me to where I can address this issue. When playing any scene on a Virtual Output from Xpression Studio it comes up as blank like in the picture bellow. Can someone help and tell me what I'm missing. Thank you.
    Blank screen on Virtual Output
    CP
  • 2.  RE: Virtual Output not playing the scene
    Is this XPression Designer edition?  What type of hardware / gpu are you running this on?  Do you get any notifications when starting XPression about failing to initialize the GPU or rendering system?
    Check in the Edit->Preferences->Hardware menu and make sure it is showing your Nvidia gpu correctly selected.
    Brian Ford
  • 3.  RE: Virtual Output not playing the scene
    Hi Brian, thanks for your quick reply we are using a Quadro M4000, and have no notifications whatsoever at launch. Could it be possible that a Monitor needs to be attached to the unit ? We use this machine for testing purpose and we only access it remotely, I don't think we have tried the Virtual Output before so I'm not sure that it even worked before. Thanks.
    CP
  • 4.  RE: Virtual Output not playing the scene
    Yes that would be it.  You do need a monitor attached; or one of those dongles that emulates a monitor's EDID.
    Brian Ford
  • 5.  RE: Virtual Output not playing the scene
    Ok thank you, very much, I will try that once I get access to the machine and come back with a confirmation.
    Cristian Postolache
