XPression Datalinq to Microsoft 365 Excel on One Drive
  • 1.  XPression Datalinq to Microsoft 365 Excel on One Drive
    Posted 16 days ago
    Hi all,
    I am having a lot of trouble trying to connect an excel XLSX file to the XPression.  I co-authored and saved on One Drive, copied the ink to the file, and opened the file in the desktop app on the XPression. When trying to set up the datalinq server, I chose AODB, select template Excel XLSX and replaced [Excel File] with the link to the spreadsheet on One Drive. When I press test connection...it spins for awhile and then returns the error message "Failure External Exception C06D007E. I tried a bunch of other things like downloading the 32 bit and 64 bit microsoft files installing with "quiet" as suggested in a different post, and I also tried to do the legacy sharing suggested in a different post all together. Is it possible to use a file on One Drive? This would be ideal, but at this point...all I really want to do is be able to connect to a spreadsheet. I am going to have over 400 Lower thirds to build, so datalinq is an important tool. I am running all of this on bootcamp, but I don't think that is the problem.
    Thanks in advance for your help,
    Layne
    Layne Dornstein
  • 2.  RE: XPression Datalinq to Microsoft 365 Excel on One Drive
    Posted 9 days ago
    Have you tried moving the file locally?
    United Kingdom
