Transition Logic Help!
  • 1.  Transition Logic Help!
    Posted 29 days ago
    Does anyone have an overview of what is going on with Transition Logic?  I've watched the videos, I've read the manual, and looked over the forums...
    I'm looking for an overview:
    • Are the conditions tested top to bottom, or bottom to top, or all at once?
    • Does it stop at the first true condition, or evaluate for all true conditions?
    • Is there some order of precedence when conditions are executed?
    • Can my IN/OUT transitions overlap?  Always? Or are there times when they shouldn't?
    • Are there general things that I should or should not do when building for transition logic?
    • Why are "text" tests different for back-to-back? (no test for contents, only for = or ≠)
    • Can you mix In/OUT, BACK-TO-BACK, & SCENE TRIGGERS on the same condition?
    • Should you mix In/OUT, BACK-TO-BACK, & SCENE TRIGGERS on the same condition?
    • etc., etc., etc.
    I have managed to make it work for a couple of projects, but it is always a struggle.  I'm currently trying to transition between Poll Question pages.  Sometimes the page will have revealed the answer, sometimes just the question, and the transitions need to be different for each situation.  This feels like it should take less than 1/2 hour, but I'm on day 3.  After I get the Poll Question page to work with itself, I eventually want it to play nice with other full pages too.  It shouldn't be hard, but has been a struggle.  Any help is appreciated!
    Kraig
  • 2.  RE: Transition Logic Help!
    Posted 2 days ago
    Hopefully someone else can give you a more detail answer, but here is a sample transition logic project used for training.
    xpp
    TransitionLogic2018.xpp   1.60 MB 1 version
