Clock - change of colour
  • 1.  Clock - change of colour
    Posted 03-01-2023 07:52
    Is there a way I can create a clock where the last 5secs change to a different colour?
    For example: 20sec clock in white text, then 5 to zero in red?
    Phil Hewson
    Xpression Freelancer
  • 2.  RE: Clock - change of colour
    Posted 03-01-2023 14:46
    Text Color changes with text
  • 3.  RE: Clock - change of colour
    Posted 03-02-2023 05:24
    Thanks Garner, it works really well.
    Much appreciated.
    Phil Hewson
  • 4.  RE: Clock - change of colour
    Posted 03-02-2023 05:58
    Just noticed, when it gets to 5 seconds, the number 5 goes white before turning red - is that solvable?
    Example video attached.
    Phil Hewson
  • 5.  RE: Clock - change of colour
    Posted 03-02-2023 09:40
    Probably your logic is slightly wrong, share a picture of it.
  • 6.  RE: Clock - change of colour
    Posted 03-02-2023 09:50
    Thanks Red, attached.
    Phil Hewson
  • 7.  RE: Clock - change of colour
    Posted 03-02-2023 09:54
    Try changing your Smaller Than block to "Smaller Than or Equal To" instead.
  • 8.  RE: Clock - change of colour
    Posted 03-02-2023 10:26
    Tried both Smaller Than or Equal To & Equal To but its the same.
    Packaged the job to see if I am doing correctly
    Phil Hewson
    xpp
    COUNTDOWN.xpp   80 KB 1 version
  • 9.  RE: Clock - change of colour
    Posted 03-06-2023 04:03
    Hi Red - do you think this is solvable? I tried your suggestions but I'm still getting a frame or two of white before the number on the clock changes to red.
    Phil Hewson
  • 10.  RE: Clock - change of colour
    Posted 03-06-2023 05:02
    I did this and it seems to work for me.
  • 11.  RE: Clock - change of colour
    Posted 03-06-2023 05:36
    Thanks Red....adding Trunc to the script, now works perfectly.
    Phil Hewson
  • 12.  RE: Clock - change of colour
    Posted 03-06-2023 05:40
    So the reason for that is that from when it changes from 6 to 5 it was actually 5.xxx so the logic see's that as more than 5. Putting the trunc there removes all the numbers after the decimal.
