Make sure your BlueBox has the Datalinq license. BlueBox App > Help > About > Licenses
Looking at your account assets in the Ross customer asset list, I don't think you have the Datalinq License for XPression BlueBox. It looks like you just have BlueBox SCE (Single Channel Edition) and XPression Developer and Tick-it Core.
If you do have the Datalinq License:
When your Project is open in XPression Developer and you open the XPression Datalinq Manager.
Have you used localhost for the Datalinq Server, or an IP address?
When the Project is loaded onto the BlueBox, the BlueBox will try and connect to the address that you have saved in the Datalinq Manager (the Datalinq Manager is saved in the Project file).
So you either need to make sure your BlueBox can reach your Datalinq server, or if you are using localhost, you need to install a Datalinq Server on the BlueBox with the same configuration (names/paths/etc).
Sent: 01-19-2023 08:23
Subject: DataLinq content through branding player.
I have a temperature bug that is auto updated via datalinq from our Flow instance. While everything works in Xpression Developer, it does not appear to be working through the BlueBox and branding player.
Chris Hamby
IT Engineer
WTVF - NewsChannel5
