  • 1.  Different Sized Outputs
    Posted 19 days ago
    Curious if anyone has any experience working with different sized outputs? (I have only worked with 1920x1080 in xPression)
    The hope would be to leave Framebuffer 1 & 2 at 1920x1080 and change output 3 to another dimension.
    I can create a new sized scene by right clicking in my 'Scene Manager' > New > Custom Size Scene. The problem with this is that when I play it out on my output, it squeezes everything to fit 1920x1080.
    I know you can have different sized scenes using Tessera and assign it where you want it to play out, is this also possible only using xPression or do you need a Tessera to make this happen?
    Dalton Paul
    Senior Graphics Producer
  • 2.  RE: Different Sized Outputs
    Posted 14 days ago
    What resolution do you want on the third framebuffer and what device is it going to feed?
  • 3.  RE: Different Sized Outputs
    Posted 9 days ago
    I'm not 100% sure, lets say 5760x1080.
    I don't know of the device yet either. More curious to see if its possible.
    Dalton Paul
  • 4.  RE: Different Sized Outputs
    Posted 9 days ago
    5760x1080 would be 3 outputs tied together side by so ideally you should use Tessera.
    However, you could try tile mapper, which will allow you to stack multiple outputs side by side or vertically to make one large canvas.
    It will require all 3 of your outputs to do this and you will need to wire it correctly to the other end as you will still have 3 separate HD-SDI outputs that will need to be routed correctly to the final destination.
  • 5.  RE: Different Sized Outputs
    Posted 20 hours ago
    Thanks for this, Will look at this and see if this satisfies what we are looking for.
    Dalton
