I get the scene from the project, which I get from the engine. We have a few xpfs and the one with the issue isn't the first, however, it is the first that tries to access a text object during our initialization process.
_engine = new xpEngine();
for (int n = 0; n < _engine.ProjectCount; n++)
_engine.GetProject(n, out xp);
xp.GetScene(m, out _scene, false);
I get this error with 10.5 as you expected. I will see if I can isolate the issue or get it to happen in another xpf.
thanks for your help
dave
David Ball
Sent: 12-13-2022 15:18
Subject: Error trying to access text in xpTextObject
I never uninstalled Xpression. I have only ever had the developer version on my desktop. I did try to re-install (10.55 I was using 9) and had the same result. I cleared the script engine cache.
I do find that if I do the following
_scene.GetObjectByName("xOffsetVal", out temp);
_temp = (xpTextObject)temp;
_temp.Text = "a";
string offset = _temp.Text;
it doesn't crash but if I look in the debugger it shows the value of offset as null. Also, it shows the value of _temp.Text as null. The value in the text object in the xpf is 70. The value never gets updated to "a"
thanks
dave
David Ball
Sent: 12-13-2022 10:30
Did you uninstall any XPression software from you PC at any point?
For example, did you install Designer and Studio and then uninstall Studio?
I would try re-installing XPression (whatever edition you have). You could also try deleting the script cache folder (close XPression before deleting):
XPression > Edit > Preferences> On Disk Cache > Script Engine > Path
Sent: 12-07-2022 16:43
I just updated from Xpression 9 to 10.55 I get the error when I run the following code:
System.AccessViolationException
HResult=0x80004003
Message=Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
It happens on the last line of code. Is there a new setting for text objects to allow this to work?
David Ball
