  • 1.  INCREASE AUTO-SQUEEZE PER VISIBLE SCENARIOS
    Posted 16 days ago
    I have a Full Screen graphic with 3 columns.  First column is desginated for numbering 1-10.  2nd column is for a line of main text.  The third column is for additional info.  I am seeing a top ten list of baseball teams ranked 1-10 / team name / record.
    I want this graphic to be versatile.
    I want the numbers column to be visible/not visible.  If not visible, I want column 2 to shift over on the x-axis and I want to increase the auto-squeeze on the column 2 main text.
    I also want the 3rd column to be visible/not visible.  If not visible, I want column 2 auto-squeeze to increase as well.
    I can get some of the visual logic to make this happen, but I always get stuck when trying to effect the same line of text.
    Also, there can be various scenarios
    Scenario 1: All 3 columns visible and no changes
    Scenario 2: Column 1 is not visible and Column 2 shift on x-axis and increases on auto squeeze (visual logic attached)
    Scenario 3 - Column 1 & 3 are not visible and Column 2 shift on x-axis and increases on auto squeeze (more than scenario 2) - help
    Scenario 4 - Column 1 is visible, but column 3 is not.  Column 2 then does not move, but needs a different auto squeeze number because of column 3 - help
    If seems that I can create a shift and increase in auto squeeze, but that's where I get stuck.
    Please advise if you can..
    ASB
    Graphics Designer II
  • 2.  RE: INCREASE AUTO-SQUEEZE PER VISIBLE SCENARIOS
    Posted 16 days ago
    Hi,
    you need 4 different states like - visible yes / visible no for col 1 or col 3:
    Col1 / Col 3 / Add
    Yes yes = 2
    No yes = 1
    No no = 0
    Yes no  = 1 = 10 = 3
    With a add you would get 3 states and need to make out of the yes no and no yes a seperate one. with that visual logic you get out off add the 0/1/2/3 - 4 different states that you can then use to do later the things you want.
    Regards Nicole
    Nicole Schindeldecker
    FERNSEHGRAFIK
  • 3.  RE: INCREASE AUTO-SQUEEZE PER VISIBLE SCENARIOS
    Posted 16 days ago
    Thanks for the reply....
    I will play around with what you sent and let you know how it goes.
    Thank you,
    Anthony Bordignon
    XPression Graphics Designer | Stadium
    1901 W. Madison St.
    Chicago, IL 60612
    M: 630.890.2287
    watchstadium.com I  Welcome to the game – sign up now for updates
  • 4.  RE: INCREASE AUTO-SQUEEZE PER VISIBLE SCENARIOS
    Posted 14 days ago
    Nicole -
    SUCCESS!!!!!!!!!!!!!!!!
    Thank you so much - maybe one day I'll understand what I just did.
    Thank you again,
    Anthony Bordignon
    1901 W. Madison St.
    Chicago, IL 60612
    M: 630.890.2287
  • 5.  RE: INCREASE AUTO-SQUEEZE PER VISIBLE SCENARIOS
    Posted 13 days ago
    Hi Anthony,
    so great feed back :-) So many people at ROSS helped me when I started and we all started like that.
    I am glad to give something back - no worries will not take long to get there.
    Have lot's of fun with Xpression !
    Nicole
    FERNSEHGRAFIK
