Was just messing around with some color changes and was curious if there is a way to pull these values through scripting.
In the image attached you can see I have 6 published objects:
1. Text Object - Message
2. Quad Object - Background
3. Quad Object - Text_Color_Picker
4-6. Text Objects - RGB Values the operator can manually type in
On the Quad Object, the 'Color' tab is selected where you can generate any color (dark blue is selected for the text).
For this particular scene the operator can select a color and manually input the RGB values into the respected Text Objects (4-6 - underneath). This will allow the operator to change the text color for this particular scenes use.
In the hopes of simplifying this even more, I am curious if there is a way to pull the value (hexcode) or HSL/RGB values of that Quad Object when this 'Color' tab is selected.
I looked in the SDK but couldn't find anything I thought would relate to this specific 'Color' tab. I thought the OutputRed/Green/Blue property of the quad object was it for a second but that returns a boolean and not the respected RGB values.
Dalton
Senior Graphics Producer
