I'm working on a banner that I'd like to have dynamically scale via Transition Logic. The banner changes width based on the length of a textbox, and the goal is to have it expand and shrink when going back-to-back with another quad revealing the text. The ending Position.X of the revealing quad should match the width of the banner. I'm currently stuck getting that quad's Position.X to update using SetKeyFrameValue (I have a scene director that I'd like to update a keyframe with that value). The script is below. Any help is appreciated! Thank you.
'script to set banner elements
engine.DebugMessage("****START SET X POSITION SCRIPT****",0)
dim objPlate, objMask as xpBaseObject
dim animText as xpAnimController
dim animKey as xpKeyFrame
dim varFrame as integer
'retrieve scene objects
Scene.GetObjectByName("Plate Main", objPlate)
Scene.GetObjectByName("Plate Mask", objMask)
Scene.GetAnimControllerByName("Text WIPE", animText)
animText.GetKeyFrame(objMask, "Position.X", 30, animKey)
engine.DebugMessage("Objects Retrieved",0)
'set x position based on banner plate scale
engine.DebugMessage("Current Mask X Position = " & animKey.Value,0)
engine.DebugMessage("Current Plate Width = " & Text,0)
If Text = "0.850" Then
varFrame = -849
engine.DebugMessage("Condition A",0)
Else If Text = 1 Then
varFrame = -660
engine.DebugMessage("Condition B",0)
End If
animText.SetKeyFrameValue(objMask, 30, "Position.X", CDbl(varFrame))
engine.DebugMessage("New Mask X Position = " & animKey.Value,0)
engine.DebugMessage("****END SET X POSITION SCRIPT****",0)
John Robbins
Graham Media Group INC
