  • 1.  Stream Deck and xPression
    Posted 26 days ago
    Hi!
    Is there a way to disable that taking items on air from the stream deck opens the page in preview?
    Chris Nicolay Wernersen
  • 2.  RE: Stream Deck and xPression
    Posted 21 days ago
    Which Streamdeck command are you using?
  • 3.  RE: Stream Deck and xPression
    Posted 21 days ago
    Hi!
    I'm using Stream Deck with the Companion app. I'm using SEQI-commands.
  • 4.  RE: Stream Deck and xPression
    Posted 21 days ago
    SEQ commands both move the focus of the sequencer and trigger the take item. Switching to the TAKE command will trigger the take item, but not move the focus bar. The focus bar movement is triggering your preview.
  • 5.  RE: Stream Deck and xPression
    Posted 20 days ago
    Ok, thanks! :)
