  • 1.  Trigger "Disable Item" from DashBoard
    Posted 08-16-2022 15:36
    So I would like to trigger the "disable Item"(Ctrl+D) command from a Dashboard button and I was thinking a GPI trigger would work but that command only listed under local shortcuts. is there a script I can use to set that command as a GPI?  The idea is to run a group on loop and disable/enable specific take IDs from Dashboard. any help or insight is greatly appreciated.
    Jarod Valentin
  • 2.  RE: Trigger "Disable Item" from DashBoard
    Posted 08-16-2022 15:39
    dim takeitem as xpTakeItem
    engine.Sequencer.GetTakeItemByID(1, takeitem)
    takeitem.Disabled
  • 3.  RE: Trigger "Disable Item" from DashBoard
    Posted 08-17-2022 14:14
    For the "takeitem.Disabled" do I need to set boolean values?  The way I see what you put is that it should just disable the identified take item from the line above it.  I got it to compile/run a Public Method(cue,execute,setfocus), but it won't compile/run "Disabled"?
    Jarod Valentin
  • 4.  RE: Trigger "Disable Item" from DashBoard
    Posted 08-22-2022 05:49
    Try,
    takeitem.Disabled = true
  • 5.  RE: Trigger "Disable Item" from DashBoard
    Posted 28 days ago
    This worked, thank you!
    Jarod Valentin
