  • 1.  Vertical Expanding Box with Text
    I'm trying to create facebook style comment box that populates with questions. How do I get the comment box and the text to expand from center?
    Erik Sams
  • 2.  RE: Vertical Expanding Box with Text
    You need to set your text to centered.
    And you need to make sure your pivot point of your object is in the center.
    be sure the quad is a child of the text.
    then use auto scale.
  • 3.  RE: Vertical Expanding Box with Text
    Hi Sams.
    If you want to style facebook, you'd better use a plate object with rounded corner
    Below a scheme in visual logic
  • 4.  RE: Vertical Expanding Box with Text
    Using the vlogic below, I can get the slab to expand with the text the way I want, but the text flows over the slab the longer it gets. I also need to anchor the "Name" textbox to the top of the slab so that it repositions as the slab size increases and decreases. Any suggestions would be greatly appreciated.
    I used the vlogic you provided however my text box is no longer visible
    Erik Sams
  • 5.  RE: Vertical Expanding Box with Text
    Your pivot points for the textbox and baseobject need to be aligned.
  • 6.  RE: Vertical Expanding Box with Text
    Posted 4 days ago
    Hi Sams.
    In this case  use that scheme.
